If I have two base stations, can I have more than 5 cameras on one account?
If I have two base stations can I have more than 5 cameras on one account ?
5 REPLIES 5
I think they are pretty clear about 5 camera limit. Nobody says you couldn’t have two accounts that i can see. But then you couldn’t view all of your cameras at once.
You can use multiple accounts and then use Settings, Grant Access from the new accounts to the original account's email address so all cameras are seen in one login.
Thanks. Since i have two base stations, that worked great. The only problem is that i can’t edit the referenced base from the primary login. Not a big deal once i get it setup the way i want it. I can see all 6 cameras on one login.
