IPhoneX lock screen button malfunctioning
  • 8 Replies
  • 5582 Views
ehardin13
After opening the app on my IPhoneX my lock screen button doesn’t work. Has anyone else had this problem?
8 REPLIES 8
JessicaP
Hi @ehardin13,
Which lock screen button are you referring to on your iPhone X?
d12bn
How are you using the button after a notification?
ehardin13
Hello, it’s the power button on the right side of the phone..
ehardin13
Hello,
Yes, after a notification, I open the app, view footage, close the app and try to lock my phone and it will not lock using the button, it will lock after timing out. The button is still functional to power down the phone. I’ve done a hard reset and it fixed the issue, but after opening the arlo app the issue starts again. Thanks
JessicaP
Have you tried to log out, uninstall the app, restart your iPhone, and reinstall the app to see if that helps? Do you know when the issue happens before the phone starts to lock itself?
ehardin13
I haven't tried that, but I will. The issue is with the lock/power button after I open the app. It will not lock my phone when I push it. The phone will lock after I let it time out. I’ll try your suggestion and see if it’s a fix.. Thank you.
ehardin13
What data will I lose if I delete the app?
None. It's stored on the servers.
  • 8 Replies
  • 5582 Views
