IOS, wife’s old phone”s” still show in Geo
Make sure you delete the correct device as they may have the same names. If they do you may have to prove which one works with the wife’s new phone so it’s not deleted.
I believe that the only method is to remove her from the grant access list is in settings. Then send her a new invite.
Once you set it up (even if it is only for one phone) next time when you re-open the geofencing mode to edit, you will get kind of different screen where all settings are on the same/single page. So this is where you will see Enabled Mobile Devices under Details section. That’s where you will get the Edit button on the tap right.
Hope it helps
You will have to delete her as a granted access user to remove the device(s).
I will look in to another option and to verify this process as well.
Hi @freebird316
Regarding this statement,
"Removing and adding back crests another iPhone object and does not remove the old"
Does this occur with the new Arlo app version 3.6.8?
I have the exact same problem with my wife's last 2 phones on my Arlo Pro System and 3 cameras. I deleted her grant access in the settings but the geo fencing still shows her 2 phones under Enabled Mobile Devices and under Push Notifications. After wasting a lot of time trying to figure this out I deleted her Arlo account completely and deleted the app from her phone. I'll reinstall the app on her phone later and create a new account for her. If that doesn't work I'm going to buy a new system.
Thanks for your feedback @MarkoKoskenoja
We are looking in to this and hopefully have a resolution for deleting devices soon.
