I want to buy a new camera for my arlo pro 2 VMS4430P. Which ones are compatible?
  • 2 Replies
  • 743 Views
bexric
Hi I want to buy a new camera for my arlo pro 2 VMS4430P. Which ones are compatible?
This depends on what base your system came with.  Details are here: https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
Note that newer cameras (starting with the Ultra in 2018) will require a paid subscription for cloud storage.
Remember the arlo Pro and Pro 2 cameras ( yours are Pro2 ) will work fine and not require a subscription if lees than a total of 5 ( your kit has 4, so it would be 1 more )
As mentioned the newer cameras most will work with the older base but require a subscription...
also, there is no charge if you want to update the base unit or add more bases.
  • 2 Replies
  • 744 Views
