I want my camera armed at all times but only notify me when away
I want my Arlo Pro 2 camera to be armed at all times, but only notify me when one or both are away from the house? Can this occur?
Yes though not sure about the "one or both" being away part. Probably just when you're away? But you might get sick of the notifications.
You'll need 2 different Modes. One could be Armed but probably easiest to use two custom designed modes.
Create the two modes and create the rules that you want. In one of the modes, have the rule (or rules) you want to include notifications.
Then on your mobile device, edit Geofencing. Set the home mode as the mode without notifications. Set the away mode as the mode with notifications.
IIRC, if you have both devices as geofencing devices, you can only have "when both are away" to be the away mode. Hope that helps. Also, were you going to ask something different as the title of your post doesn't coincide with the question
