I just bought a new arlo pro 2 and the rubber plug won't stay in the the charging port
  • 2 Replies
  • 851 Views
Dth0mas
It may be a bit deformed. You can try wiggling it into place to see if you can get it to stay or swap at the store.
d12bn
Is it in cold temperature? If so warm it up. If not just wiggle it around and keep pushing. I find The tab that holds it on needs to be pushed in a little bebore the cover. Good luck
  • 2 Replies
  • 852 Views
