I have the base station with 2 Pro2 cameras. How many more cameras can I add to the system?
  • 1 Reply
  • 823 Views
lnorda
Are you asking how many more legacy cameras you can add and still get free cloud storage?
Or are you asking how many cameras you can add to your existing base station?
You can have up to 5 legacy cameras in the system, and still get free cloud storage.  Base stations support up to 15 cameras - though often the range of single base station isn't enough with that many.  Also, at some point you'll start missing recordings if too many cameras trigger at the same time.
If you have an older system, the base likely won't support the newer cameras.  https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station.  Another consideration is that the newer cameras require a paid subscription to get cloud recording.
  • 1 Reply
  • 824 Views
