I have the new app as of 12/12/25 (surprised forced update) the Modes that I have are existing modes but I do not know how to enable them in the new app. When I select Custom Mode from the "Dashboard" then Custom Mode on the "Modes" page, my custom modes are select able and are editable, also deletable.
But how do you enable a custom mode???
The old app had Mode screen/list where you could select the mode and it would be enabled or you could use the "Schedule" mode and configure tod for mode(s) to be active start time(s)/end time(s).
I AM NOT ASKING HOW TO "SCHEDULE" CUSTOM MODES, JUST HOW TO SELECT/ENABLE
I UNDERSTAND THAT ARLO IS SUPPOSE TO BE ADDING/ROLLING OUT SCHEDULES OR SOME SCHEDULING FUNCTIONALITY
To enable a custom mode, go to Dashboard and click on Custom Mode. That takes you to Routines where you can select the specific custom mode you wish.
PLEASE NOTE: “
But how do you enable a custom mode???”
You should see a custom mode control on the dashboard. That changes the system mode to "Custom Mode" when you press the tile. Not very useful, since you can't select a particular Custom Mode. But it does give you one more. Scheduling, etc isn't rolled out yet. So these modes are still a work in progress.
I don't see "Custom Mode" in Dashboard.
Do you have to have a paid subscription to see this?
I finally understand how to enable Custom Mode(s)
