  • 1871 Views
vsukhotin
Hi,
I have 2 base stations, and 6 cameras that I need to wrok, in 2 different locations (One in EU, one in Dubai).
I wanted to connect the 6th camera, and I cannot do that because I need to suscribe. Tried to subscribe, chose the plan, and got redirected to the Portal. All goo so far, but when I press the button "Upgrade Plan", the screen loads, and nothing happens, then just goes back to the same screen over and over again.
Since you do have plans for the EU, I cannot see any reason why I cannot upgrade my subscriptions.
Thank you.
Run a second account, then you can have up to 5 cameras on each base
AncientGeek
Hero
Hero
Also try a different bowser.  Sometimes that helps.
One way to do it is to use the EU account to set up the second system in the EU. Shut it down and move it to the new location. Having done this, all cameras will be on the upgraded EU account.
  • 1872 Views
