I recently purchased the Arlo Pro 2, and I want to set it up so that the siren activates when motion is detected by the cameras. However there is not an option for this when setting up or editing a rule. The only options are “Do nothing” or “Record video”. See attached picture.
Any ideas about how to how/where I can find/activate this option?
Yes... you have to EDIT the normal mode and then pick camera... once you pick camera, you must add DEVICE and that option allows you to pick the siren alert
