I have an WiFi range extender to allow WiFi service down to another blding on my property. I want to put cameras at the building but don’t know how to connect the Arlo base station to the extender. Need help!!!
A wifi extender for the base unit needs to have an Ethernet port.... it will NOT hook in directly via wifi
Yes it is connected by way of an Ethernet and it finally connected!! Now I can’t get the Arlo app to add/locate the base station. Have checked all connections, etc. Any ideas?
What are the LEDs showing? The power and Internet LEDs need to be green and the Camera LED should be off or amber.
Is this a new install? Has the base been used before by anyone? If so, they would need to remove it from their account before you could claim it.
Maybe try reconnecting the base to the router ethernet, and then try adding it. Once it's in the account, you should be able to move the base with no problem.
FWIW, changing your ISP shouldn't have required you to remove/re-add the base.
