Hi, what is the watts of the Arlo Pro 2 charger? Can I charge it here in the Philippines or I need an adapter? I dont want it to explode.
Thank you!
Thank you!
Input voltage spec is 100-240v 50/60hz. Output is 5vt/1.8A and 9vt/1.1A (the latter being quickcharge).
It should work world-wide, though you may need an adapter on the plug.
Thank you!
