How long does recording stay in cloud?
i need to get a recording out of the cloud how long are they stored for
That is going to depend on your subscription. With the Basic plan, the recordings remain in the cloud for 7 days, 30 days for the Premier plan and 60 days for the Elite plan. I have read that someone updated their plan from 7 days to 30 days and the older videos showed up, but that is a 50/50 chance. Do you not have any storage device inserted into the USB port? Those videos will stay there until the device fills up.
Brian
Yes... it's a chace as to how long. In the past, if you upgraded the service level you could get back to the max of 60 days.
But just last week, a person upgraded and was only able to retrieve back 10 days worth...
All depends on what's going on with the far end changes.
1) run a usb speed stick backup to keep all your videos, a 64gb would be plenty for most, allow it to over write when almost full
2) NEVER delete anything as they will auto delete on you service level time frame
