How do i turn on one camera with siren alarm, and not the other one.
Have a read first, then find the bit about the base siren.
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
Based on the vmb4000 which has the siren built in. For the wanted mode of operation, edit the rule for the camera that you want to trigger the siren and add device which would be the siren.((o)).
Beware that disarming the siren using the app or the base top button will not disarm the system. You will need to do this as a second step.
i dont understand sorry.
