How do I turn off the motion sensor?
I’ve got one of my cameras mounted in the house but I can’t figure out how to turn off the motion sensor. I just want to use it as a live view camera. Any ideas. I turned sensitivity to one and it still goes off.
You should be able to disable motion detection from the camera rules for the running mode.
Select the mode page from the dashboard, see what mode is running, open the mode list page and then open the wanted mode to show the camera rules list. Then just delete the unwanted camera rule unless you want to keep audio detection available.
