How do I turn off Audio Notifications
I have the audio and speaker settings turned off and sensitivity turned down very low but I keep getting audio warnings on a particular camera. What am I doing wrong? I don’t mind getting audio warnings but if it’s a windy day or something it constantly goes off every minute, any suggestions would be appreciated. Thank you.
if I may ask a second question, are they still making the Arlo 2 pro camera?
The audio and motion notifications are set within the camera’s rules of each mode.
Edit them to disable audio trigger when windy. Adjusting the audio sensitivity is usually not sufficient to prevent gusty winds triggering.
The pro2 is no longer in production. Closest model is the outdoor essential but needs subscription for cloud storage.
