How do I setup Geofencing to a schedule at night?
  • 1 Reply
  • 1415 Views
mbeer98
So I’m wondering if I’m missing something here. I’d like to use the geofencing option because when I am home I frequently am working outside. The problem is it seems I would have to go into the app every night to turn off the geofencing and arm the system before I go to bed. Is there any way I can have the system armed 24/7...disarm during the day through geofencing...then rearm from, for example, from 10pm to 6am, without having to continually go into the app and change settings?
ShayneS
Hi @mbeer98
If you would like to set a schedule & use it for the Geofencing feature, you can follow the scheduling article below, then set your SELECT MODE > away/home to follow the schedule you create.
How can I set a schedule for my camera in my Arlo account?
  • 1 Reply
  • 1416 Views
