how do I extend the length of recording on the Arlo Pro2
Edit the mode...for example ARMED....or whatever mode(s) you are using. Then edit the rule for the device (or event trigger and then device) and change the length of time on the Record Video parameter.
I will try this later this evening, thank you
Thank you for the info it worked perfectly.
You are welcome.
