How do I disable "Create Activity Zones" warning?
Copying from a closed post since this issue somehow came back.
I keep getting a little caution icon on all my cameras telling me I should set up activity zones. If I dismiss them they'll be back next time I'm in the app. I don't want to set up activity zones on all my cameras, some I want to watch the entire frame. I could just set up a zone (like the entire screen) to make it stop bothering me, but that seems stupid. I looked through the options, but I don't see a away disable that warning.
*Edit - I put this in Community Feedback before seeing the note about what this forum is about. Please move it to the appropriate board. As this issue pertains to the app and not a specific camera, I wasn't sure where to post it. Thx.
Hi @evillama
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
As you know, set up a zone but you don't have to use it.... doesn't matter how big.
It's the only way I know of to eliminate the warning.
