How do I delete my old arlo pro 2 account and set up the system from scratch? Is it as simple as "Remove device", i.e. the HUB.
I want a complete new setup with another email-address as the master/owner of the complete installation.
Another question: Some of the functionality mentioned in the manual is missing in the app, i.e. to invite a user or with auto-sign-on off?
There is no need to delete the account. Just do what you suggested, remove devices and then add back whatever it is you want to use.
What app is this?
Just another user
