How do I connect Base Station (Arlo Pro 2) to WiFi? Don't have ethernet cable on modem
  • 2284 Views
PeterTalbot
I only have a PC with windows 10 and NO modem that i can connect the ethernet cable to. i do have wifi how do i connect the base staion to wifi?
thanks
Usu, the base is plugged into a router or switch, but with no router but only wifi, you will need a wifi extender with an ethernet port...
hook the extender into your wifi and then the base into the extender's port
brh
@PeterTalbot
How are you connecting to the internet? We need to know that before someone can help you.
Brian
PeterTalbot
Thanks Tom Mac and brh. The short answer is no I cannot, without using something like an extender....
I wish Arlo would wake up to the fact that not all of us use a router...
I use a mobile data 4GX modem by ZTE with a sim card in it ....no such thing as a ethernet port in that little one...
  • 2285 Views
