Hi,
Found this topic here, but its closed, so cant ask questions there anymore.
How and where do we find the recorded timelapses created with this?
https://community.arlo.com/t5/Arlo/Setting-up-time-lapse-recording-with-IFTTT/td-p/1338158
They would end up in the Library or other default dir spec'ed by the IFTTT
Thanks, im new to this, where would i find that library, or where do i find the IFTTT settings for this?
The Library is on the top row of either the app or web page....
IFTTT( if this then that ) is a third party integration option that can run Arlo.
do a google search for more info
I don't own an Arlo yet, but I want to make sure it can capture time lapses when I do buy one. Can the Arlo Pro 2 and Arlo Pro 3 both record time lapses with the built-in Arlo software? Or do I need to setup an IFTTT recipe to get it to work?
Thanks!
Hi djsteen,
We don't have time lapse available on the Arlo app on the phone device or on the web client on the computer. Feel free to support/kudo the idea of having one here: Timelapse feature
