How Do You Get The Backs OFF The Mounting Hardware?
  • 1396 Views
Cefmanno1
How do you get the backs OFF the mounting hardware ?!? Both the indoor and the outdoor types.
slompochomp
Luminary
Luminary
what "backs" are you refering to, can you post a picture?
Arlo Pro 2 Quick Start Guide
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
Cefmanno1
There is a piece that gets secured to the wall. Then the bracket attaches to it. The piece that goes on the wall seems to still be in the bracket and I can't get it out.
slompochomp
Luminary
Luminary
mine came as one wall mount piece and does not come apart... I don't think you need to , just slide the screw in to the slot.
  • 1397 Views
