  • 7452 Views
itornell
Arlo Pro 2  I don't understand what checking off the "filters" does, and I don't  understand what half of them mean.  Am i adding (eg) "people", or am I eliminating them?
Assuming you mean Arlo Smart filters, not filters in the library tab, tou're adding the capability.
itornell
There are Filters to check off in the Library.  I do not know what a lot of them mean and what happens if I check, it
When nothing is cheecked, everything is displayed. When you select one or more filters, only those things are displayed. Sometimes folks forget that a filter is set and then wonder what happened to their videos so be sure to reset (clear) the filters when done.
It's just a way to maybe make it easier to view certain activities and/or cameras.
  • 7453 Views
