How Do I Get Help Setting Up My System?
  • 1773 Views
Amyk
I need help setting up and installing
Streak2
Master Master
Start by reading thrugh this
https://arlo.com/en-us/images/documents/arlopro/arlo-pro-bestbuy-QSG.pdf
then get get back to us here with anything that you don't understand.
ShayneS
Hi Amyk,
I have provided a link to a youtube video that should help you get all setup. Feel free to ask any questions, We have plenty of people here to help.
How To Install Arlo Wire-Free Smart Home Security Cameras
Streak2
Master Master
Amyk,
Please note that the video that @ShayneS has directed you to is for the original wirefree Arlo and not your Pro 2. Your Pro2 has a single rechargeable battery and the sync button is on top of the base and not on the side as in the video, your base also has a siren built into it which the original does not.
The rest of the setup instructions are correct as per the video and the guide that I posted above.
  • 1774 Views
