Hotspot - MIFI 6620L added direct USB => ethernet - but does not connect to hotspot
Greetings, I searched for a hotspot that has a USB and purchased an USB 3.0 Gigabit Ethernet Adapter. It does not connect. I checked with Verizon and tether is available so it might be the issue with signal strength? I have read i may need an wireless extender. I looked for a Netgear AC1200 recommended in one of the support chats and none are available at this time.. Has anyone have any other extenders they used for a successful Hotspot cellular connection?
You sure landed in the wrong forums for this question. CHeck out the Netgear forums for hotspot info.
Are you wanting ethernet to connect an Arlo base station ???
