  • 4 Antworten
  • 5756 Aufrufe
  • 1 Kudo
  • 2 in Unterhaltung
Zakman
Hi. My homeKit stopped working. I need Arlo to send the reset token please.
thx in advance
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
ShayneS
Thank you
4 ANTWORTEN 4
Zakman
Anyone able to help?
ShayneS
Thank you
Zakman
Working. Thank you
Zakman
Hi.
with Update to iOS 16.2 it stopped working. I need a reset again. 😞
Honistly, is there any chance to reset the token myself?
thank you.
