Help with setting up my pro 2 system
  • 1997 Views
kjellbrel
Last week I tried to install basestation vmb4500 using the Arlo app. Support also failed to help and instead had to use computer for locating/activating . Since I do not have a computer  I had to bring the router and Arlo kit to a friend for setup - it worked after some help from US support.
Today I tried to set up a second base and camera at the summerhouse . Same problem = the app cannot find the device ( base station) and is just scanning and scanning ( yes I have followed all fat/trouble shooting such as reset etc).
This app is no good.
I assume I have to drag out a computer to the summerhouse to get connected through the web instead. Can someone remind me how to connect. is it ethernet cable from computer to router to basestation or only ethernet cable from computer to basestation ?
@kjellbrel wrote:
so one cable from computer to router and one cable from router to base station ?
Yes.
Both the computer and the base station are connected to the router (perhaps through an ethernet switch).
You don't connect the base station to the computer.
kjellbrel
Yes.
  • 1998 Views
