Help with installing new Arlo PRO 2. 2 are in different countries. Can't terminate one of them?
I have 2 different Basestations with Arlo PRO 2. One is placera in Sweden and one in Spain. I took two of the cameras bought together with the Swedish system and are trying to install them in the Spanish system. But it seems impossible! I have terminated one of the Spanish camareras and have no problems to reinstall them again. However the cameras bought together with the Swedish Basestation can not be found by the app.
Anyone who can help me with a solution?
When performing the installation both the led on the camera and led on the front of the basestation are flashing rapidly after some minutes, indications everything is OK, however the app still will not find the camera!
Please help!
Did you use REMOVE DEVICE from the system before moving cameras?
Only reset for the camera is pulling and replacing batteries....
Yes if the other base is online, you can remotely use remove device.
I cant find any other connected cameras on the app than the two in Spain (since 1 year) and the two in Sweden (installed 6 month ago) all of them are working good. Can the cameras I have here still be connected to base in Sweden?
The option seams to be to bring the cameras back to Sweden and try to install them with the Swedish base.
Have you tried to sync them directly without app/web?
Press base sync button ( don't hold ) and after press camera sync button
Yes, I have, and it looks like they are synced without problem. The sequence ends up with that the leds rapidly are twinkling in blue. But still not a sign of the camera on the app. Just a text on the phone or on the IPad telling something like “ Looking for units”, in Swedish though!
Have also checked the WiFi and it’s OK. And when terminating one of the existing cameras I have no problems to reinstall the existing camera again. However not the new one. Perhaps the new cameras still are paired to the Swedish base already from the delivery?
I have seen this before... the cam appears to sync ( rapid blue flash ) but doesn't appear in list.
Somehow the camera thinks it's sync already .
Only option is a reset of the base and then starting over as if new with all.
I tried to terminate and restart the base and your suggest was the key! I managed to install one of the new cameras. The second one refuse to lighten up the blue led. I can only see a blue flash when I insert the battery. I have changed the battery but with the same results! Any clue?
Looks to me like a defective unit!?
Thanks for the help!
Hey Gip54,
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Any idea what has gone wrong?
Have changed the battery and recharged the battery but still no blue light on these 2!
I have waited for several days now, for an answer by mail. Did put a second mail to support some minutes ago.
Have also tried the live chat several time but no answer.
Best Regards
Gert Maulin
Let me reach out to you via private message to gather more information from you in regards to your experience with the support team.
