  • 7 Replies
  • 3548 Views
markytcd
Scratching my head on how to position the Arlo Pro 2 Wireless to cover the door and have the camera out of reach as per the photos. Unfortunately the Eave is reachable from the door step. The camera ideally would need to be postioned to the right of the door (as you look at it) pointing/angled covering the left of the door down the drive.
Could I kindly ask for any advice?
7 REPLIES 7
michaelkenward
Sensei Sensei
Sensei
Pictures will not land until approved by Arlo moderator. Attachments arrive instantly.
Just another user
markytcd
Thanks for the info...please see the door in the attachment.
markytcd
michaelkenward
Sensei Sensei
Sensei
Some of us can get in quick.
Front%20Door%202
Arlo promises that one day we will have a front doorbell with a camera built in.
Would that work for you?
Just another user
markytcd
Front%20Door%202
Ideally I want to get a view of the person walking up the drive to the door. The drive runs parallel to the house to the left of the picture.
Use of an outdoor threaded mount would be a good start. It not only is more secure (you can use a security cable with a little imagination, too) but sticks out some allowing more freedom of positioning to capture the view you need. I think I would mount it on the outside of the porch overhang to help minimize the ability of someone attempting to remove it.
markytcd
@jguerdat Thanks for the advice. I will try the position suggested for coverage/motion etc.
  • 7 Replies
  • 3549 Views
