Help installing devices
no mobile app nee d to connection
Can you say more on what the problem is?
Are you saying you don't have a device that supports the mobile app?
Or maybe that the mobile app isn't working for you?
Something else?
Is this a new base? Or was it purchased used?
Are you seeing it in your router's attached device list?
new
no see it
@gerges_0007 wrote:
no see it
Are you saying you don't see it in the app? I was asking specifically if you see it in the router's list of attached devices (not the app).
@gerges_0007 wrote:
new
That might actually be the problem. The VMB4000 was launched back in 2016. In 2018, Arlo split off from Netgear, and their servers were rehosted. Old inventory from 2016-2018 won't be able to connect to their servers anymore.
I think the best option is to exchange the VMB4000 for a current hub (VMB4540 or VMB5000).
