I accidently removed one of my Arlo Pro 2 camera's and can't see it anymore. I am trying to re-add it so I can see it. What do I do?
Thank you
The Pro 2 cameras can be synced by pressing the base sync button briefly - don't hold it - and then the camera sync button. You don't need to use the app. You might want to also reboot your base.
