Arlo Pro 2 camera and reinstalling it
I accidently removed my Pro 2 camera. It is not active. I am trying to reinstall it, but it is not syncing. What am I doing wrong?
Thank you
With the older Pro/Pro2, you can sync directly....
so try this;
Press the base sync button quickly,( the base camera sync should flash ), then while having the camera within 5 feet quickly press the camera sync button...
Slow blue on camera flash to quick means it worked.
