Error I am receiving the "cannot stream more that 5 cameras at once"
My Arlo app is not letting me stream my cameras. I hit play and get a message saying "cannot stream more that 5 cameras at once." I only have two cameras. So that's that even remotely possible. This is on my Android phone note 10+ this issue has been going for about a week. I've restarted my phone multiple times. Even uninstalled the app and redownload.
This is not an okay time for this issue to happen.
Does anyone have a solution for the problem: "Maximum of 5 camera streams are supported simultaneously. Please stop one stream before starting another camera stream?" I have 4 cameras and 1 camera displays this message when I try to view it live or view any recordings. I have rebooted the base station and that does not help. I have reloaded the app and that does not help. The problem exists with an android app, an apple app, and directly on the Arlo website. I called Arlo technical support and their only suggestion is to remove the camera and re-sync it to the base station. However, the camera is located at a vacation home and I cannot go there for a while (thank you Corona virus). Does anyone know if that solution works or if there another solution?
I have the same problem. Started a few days ago. I contacted Arlo technical support and they escalated the problem internally. The camera is in a vacation home that I cannot physically access for a while. Arlo support suggested disconnecting the camera then re-sync it to the base station.
I was having the same problem. I removed ONE camera and rebooted my base station, added back the camera and all is good. Sucks that you are on vacation when this happened.
I don't follow.
You are trying to fix a problem?
What are you doing and where does it go wrong?
Just another user
I am getting very annoyed at this whole Arlo system, which I am paying a monthly fee for as well. It was working fine for a year and not it has completely stopped and keeps giving me a message "maximum of 5 camera streams..." even when I am trying to live stream 1 camera. I have 6 cameras and 2 base stations in total.
I have been communicating with support but up to now, all I get is questions and asking me to do things like turning things on and off, but I still cannot access my cameras.
I am calling out for help on this as I have not had a response from Arlo (albeit the last response I provided was 2 days ago). I've even tried using the PC or iPhone to access Arlo and all devices are giving me error messages.
I notice a lot of issues with Arlo. For a product that is charging a premium price, this product and service is not fit for purpose.
Without subscription, the upper limit of camera connection is 5. You can remove the BS and Camera from the App and reset it, then reconnect the BS and camera to the App. Then check the result.
Thanks for the response, in the first paragraph of my issue raised, I have stated I pay the monthly fee for the Arlo subscription. So I am still stuck with the problem.
That doesn't seem to be @Altdahunta 's problem.
It is true that the free cloud recording for older cameras is limited to 5 cameras per account.
However, there is also a limit on the number of simultanous streams per base station (which also happens to be 5). That limit always applies - even if you are on a paid subscription. That appears to be what @Altdahunta is seeing.
There are lots of people saying that they've been seeing this error, even though they don't have that many cameras active. Likely a back-end or base station bug. One thing to try is restarting the base station.
Thanks for the suggestions, so I have been talking to the Arlo team (still waiting a response since the last communication on about 3 days ago.
Things I have done prior:
- reinstalled the Arlo software, twice
- rebooted the base stations several times (one of them I have to reboot via the app because its in a different location)
- turned off some of the cameras
- tried logging on from PC and iPhone
- provided all my Arlo information to the Arlo support team
Still doesn't work! This is driving me mad!
Any help from Arlo please???
Same here. Problem started when I was trying to live stream a particular camera to check my package arrival this morning. The camera fails to connect. I then tried another 2 for total of 3 cameras and I started to get this error message when I don't even have the rest of camera turned on. Restarted base station and turned all 3 active cameras off then them back on and still having same problem.
I agree these things should not happen suddenly. This is not the first time I've had problem with the Arlo system. The cameras suddenly disappeared a year or 2 back and I had to bring my ladder out and climb up the ladder quickly to reinstall cameras to BS and back into the house and ran out for different cameras that are mounted on the ceiling...real pain in the rear.
And trying to contact Arlo support and the link leads to non working web page...even more frustrating...
I just fixed it.
I went to my Arlo account online from a desk top computer. I went to settings and checked the subscription. For some reason I noticed non of my cameras are "participating" in my subscription plan. I don't see any problem for Arlo to charge my Visa monthly and not sure why Arlo (AGAIN) removed my cameras from my subscription.
In any case, I "dragged" all my cameras back to "activate" area and I can live stream without getting the error message now.
I hope it can help some others with similar issues.
I finally fixed this issue. Had to physically go to my vacation home, remove the base station from my account (through the app), reset the base station using a paper clip in the "reset" hole, restart the base station and add it to my account, then sync the cameras to the base station. This should not happen! I am not happy with all the different problems with Arlo cameras.
Yeah, that’s what I had to do as well.
What a shame, poor product quality and not really fit for purpose. What is the point of buying these cameras when you have to go and physically fix them?
i used to recommend this product but not anymore!
Only 2 of my 5 cameras are participating. How did you "drag" the cameras? I get a pop up box telling me to drag the camera here, but there are no cameras to drag!
You should see the other 3 cameras if you scroll down.
You can do this from either the mobile app or from https://my.arlo.com - so maybe try a different interface.
