Enabled mobile devices
  • 2 Replies
  • 2183 Views
Racquet57
Under Geofencing and enabled mobile devices, there are devices that have been retired and no longer used. Additionally, for two factor authentication, it tired to send the 2FA to one of these retired devices.
How can I delete these old devices for both Geofencing and 2FA?
Are you able to go to Settings, Profile, Login Settings, Two-Step Verification and then click on the Edit selection at the top right? You should be able to delete unwanted devices there.
Racquet57
Yes, that recipe was what was needed. Problem corrected.
Thank You
  • 2 Replies
  • 2184 Views
