Elite Subscription Supports Up To 20 But Only Shows Up To 15 Cameras. How to fix?
I'm trying to add more cameras to my subscription. I have Elite subscription. Well, on my phone it says that it supports up to 15 cameras but when I go to upgrade it says that it supports up to 20. How can I fix that? Cause I really need to have up to 20.
TMK, it only supports 15....
But you may want to consider a second base as one base can only stream a max of 5 cameras at the same time...
( no limit of the number of bases on any account )
You just would have to split the cameras into groups like inside/outside
It turns out that new allowances have increased the number of cameras for Elite to 20. My account currently shows that I can only have 15 but if I click on CHange Plan from inside Settings, Subscription it shows 20. I suppose you can try downgrading your plan temporarily and then upgrade to get all 20. I'm waiting until my plan renews in a few weeks to see what happens.
It was 15 but is now 20. My subscription renews in a couple of weeks so I'm just going to let it do so and see if I then get 20. You can try changing your subscription to Premier or basic and then back to Elite to see if you then get all 20.
