Can I Add A 6th Arlo Pro 2 Camera To My Plan?
  • 1 Reply
  • 781 Views
billkex
Luminary
Luminary
I bought the Arlo Pro 2 (5) camera package. I'd like to add a 6th camera. Can I still view all the cameras via the app & the plan I have now? or is there an addit. cost?
You can add the camera but would have to manually disable one camera and enable another to be able to see it. Not very workable. Otherwise, you can upgrade your subscription to enable all cameras at once or buy a second base and set it up on a new account with a second email address. Sync the new camera to it. Use Settings, Grant Access from the new account to the old one. Once the emailed steps are properly completed, you'll be able to see all cameras in one account.
  • 1 Reply
  • 782 Views
