Does the new Arlo Pro 2 for night vision still use the visible IR LEDs?
Does the new Arlo Pro 2 for night vision still use the visible IR LEDs? Is the visability have a longer range?
Same as with the Pro.
Something is different with the night vision as it is noticeably worse than the pro 1's so I cannot see how they would be the same and produce worse quality. Very hard to believe.
I also have poor night vision with the Arlo Pro 2 compare to the Arlo Pro 1. The LEDs look the same but I'm not sure if they are
The LEDs may or may not be the same, but the imaging sensor on the PRO 2 must be different because it's 1080p. Perhaps the Pro 2 imaging sensor is less sensitive to low light levels.
Have you tried turning up brightness to 100%?
A solution is to purchase the new Arlo outdoor light.
I was just joking. NG dumbs down the night vision capabilities and therefore forces you to buy another of their products.
