Does the new Arlo Pro 2 camera have the same infrared specs are the Arlo Pro?
I think so... not 100% sure...same shell , tho the spread of Ir may be a bit wider to account for lens change
The angle of view is the same, the sensor has more pixels. IR should be at least essentially the same.
jguerdat wrote:The angle of view is the same, the sensor has more pixels. IR should be at least essentially the same.
Per androidpolice.com: "the new camera has 1080p video output (130-degree field of view) instead of 720p like the last one. The previous Arlo had a sensor capable of 1080p, but Netgear says it's made sure the new camera has the power to record and process 1080p video without overheating."
All Pro cameras have 130 degree angle of view and always have. The difference is in the resolution, 1080p vs. 720p.
