Does arlo send an alert if there site goes down.
Is there a way to tell when away from home if the problem is at home or with the arlo sits?
No .. there is no remote way to determine if the outage is local or away at a server.
( untill you check same locally )
you could check this third party site; http://downdetector.com/status/arlo/map/
