I logged in to check my cameras today, and the layout/everything has changed.
Anyone else? I can not see all my cameras.
How can I get it to go back?
You can't. Arlo is migrating everyone over time to the new user interface.
This might be useful in orienting you to changes:
The new layout is TERRIBLE.
Previously, I had no subscription, I was able to use 2 Base stations, and see all 10 of my cameras. (5 on each base station) I guess I cannot do that anymore?
I will review your link. Thanks
You must have been using a friend account. If the second account was not migrated, you can force that by starting to add a Pro 5 camera to that account. Although that will fail w/o the camera, the workflow will migrate that account to "Feed" before you get stuck. (Note both accounts need to be migrated for you to see the shared cameras in your main account).
You can't see all the cameras in both accounts at the same time. Unfortunately you will need to switch locations to see cameras on the other base. Both locations likely are named "home" now, but you can rename one (or both) to avoid confusion. Maybe rename them to identify the base.
Yes, I plan on playing with this to see what I can do to get it close to what I had before.
Previously, as I said I had no subscription (paid no money) I had 10 total cameras. 5 cameras on the front yard base station, and 5 cameras on the back yard base station, I had set up 2 accounts 1 for each base station & had them migrated together so I could see all 10 cameras. Each camera could be controlled, etc. at the same time, this could be done on either my desktop computer or through the Arlo app on my phone. It also recorded any movements, and saved it as files for a couple weeks. I loved it.
The new layout is terrible, and NOT user friendly.
Thank you. Merry Christmas to everyone!
Previously, I had 2 base stations with 5 cameras on each, (10 total cameras)
All 10 cameras were given permissions to be viewed and operated from whatever email address account I used.
I can no longer do that. Now, I have to log in to 2 different email accounts to see one or the other.
Is there anyway to set it up like I had it before?
This new software is NOT user friendly.
