I found a bug that appears after updating from Arlo Legacy app (Netgear) to the new Arlo app on iOS 12. When I go into the list of Enabled Mobile Devices under the Geofencing settings, my primary device shows for a split second and then disappears. Therefore, I can no longer tick the checkbox on my device. However, I still see the device of a friend I’ve shared the account with, and I can tick their checkbox in the Enabled Mobile Devices page. This means that Geofencing cannot work properly and now the entire Arlo system is defective. Please let me know if anyone has found a solution to this new bug.
Hi PAJ0,
Have you uninstalled the Arlo Legacy app, reinstall the new Arlo app, and reboot your phone device to see if that helps?
The Legacy app was already uninstalled, so I did the following: uninstall new Arlo app, restart phone, reinstall new Arlo phone, then restart phone.
Unfortunately this did not resolve the app bug. Any other suggestions I could try?
Could you let me know what iOS device you're using and what iOS version you're running? And what device does your friend use?
Have you tried turning off your location services (Go to your iPhone Settings > Privacy > Location Services > Arlo. Change to "Never" and change back to "Always") and re-enabling it to see if that helps from your device disappearing? You could also read this article to see if this may help: Why isn't the Geofencing mode working?
Let me reach out to you via private message to gather more information from you.
