Yesterday I received my four Arlo cameras and was able to sync and start up every single one. However I accidentally removed camera 4 device from the app and have not been able to connnect back. I followed the steps to add a device but the camera isn’t displaying as a found device. Even though the base station and camera blinking is synchronized the camera doesn’t come out on the app as available. I tried restarting the base station, unplugging everything, and removing and reinstalling the camera battery but nothing seems to work.
Be sure to only briefly press the base sync button - don't hold it for 2 seconds. Also, you don't need to use the app or web client to sync these cameras - just do the appropriate button presses.
Be sure to press the base sync button first - it may make a difference. Second, it may be useful to remove all devices found in Settings, My Devices and start fresh. Lastly, if no resolution, you can swap at the store and/or use the Contact Support link at the bottom here.
