Date and Time Stamp of Recording Incorrect
The time stamp on videos is approximately 30 minutes off from the actual time. How can you correct the time setttigns from the cameras and the base device. I only see where you can change the time zone.
5 REPLIES 5
usu a reboot fixes time ( not zone time )
Same issue - how do I perform a reboot? Thanks.
As usual, use the power switch on the base, pull the power plug, or use Settings, My Devices, your base, Restart.
I too have the same issue. The time stamp is off by 5 hours. I've checked the setting and the time zone is correct. Should I do a reboot?
Yup.
