The time stamp on videos is approximately 30 minutes off from the actual time. How can you correct the time setttigns from the cameras and the base device. I only see where you can change the time zone.
5 REPLIES 5
usu a reboot fixes time ( not zone time )
Same issue - how do I perform a reboot? Thanks.
As usual, use the power switch on the base, pull the power plug, or use Settings, My Devices, your base, Restart.
I too have the same issue. The time stamp is off by 5 hours. I've checked the setting and the time zone is correct. Should I do a reboot?
Yup.
