Dark night vision
  • 7 Replies
  • 2655 Views
Cheryl60
Just brought the Arlo pro 2 cameras my night vision is so dark I can't make out anything . Both camera are the same.Any help would be great.
7 REPLIES 7
Verify the IR night vision is on in settings....
If so, pull battery and replace again... test in a dark room
Remember that the IR light is only good to aprox -20 ft
Cheryl60
Thanks Tom, checked setting and night vision makes no difference if it on or off. Took cameras down today and done the batteries in and out no change. Daytime is great night they are useless.
Jimmymack
The night vision pretty much sucks all the way around. What a joke that they even offered night vision because everybody knows that it makes no difference this is totally false advertising
ShayneS
Hi @Cheryl60
  Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
Cheryl60
Going to do this tomorrow, everything I've try has not worked. thank you.
Here a recent Pro2 night vision pic... ( which in my opinion is not as good as the Pro at night )
Deer is about 8 ft away , trees in back about 20+ ft which is about max for night vision
Cheryl60
Thanks for your reply. I'm so disappointed by the night vision, could not make out any person on it or car.
  • 7 Replies
  • 2656 Views
