Customer support
What is the phone number for customer support?
They don't publish one (and googling will usually lead you to a scam support site). Instead you access support via the app (not my.arlo.com).
Customer support does require that you either have a subscription or a camera under warranty.
You might follow up with the details of your problem, since we can often help here.
