The detection zone is inside the box.
I have since setup three zones to cover the areas not to be excluded. I have no idea what has changed to cause this. It was my first crack at activity zone since going with external power on the camera.
I have a warning "!" symbol and its wanted to be connected to power to enable activity zones on one of my camera views. Its smart enabled so shouldnt be an issue. How can I get rid of this error. Pulled the battery and re-synced the camera, logged out and in again and it's still there. Please help.
If you haven't already, Can you reboot the base station, try and create these zones on your computer & test again. You can also try and remove & re-sync the camera to the base station.
Did the above and cleared the "!".
I created a zone and saved.
Went back to "Devices" page and "!" has appered again on that camera.
This should'nt be happening as its Smart enabled.
Did you remove the camera from the settings & re add it? Can you remove & re add the camera to Active Cameras in the (manage) section?
