  • 2 Replies
  • 4426 Views
  • 2 Likes
Nanookie
Just setting up my first pro2 cameras and lights and trying to work through understanding modes and rules. I am trying to ensure that I dont have "conflicting" rules and understand what the conflicting rules would do.
Scenario:
Lights - Set on timer, then motion activated.
Cameras - Set on motion and sound, also have a rule established that when certain cameras activate, that that certain lights activate.
So, what i'm trying to understand is this. On my front porch, my arlo light is behind a post to make it less visible. The camera will activate first based on motion. It will start recording, and a rule is established to activate the light. But if a person is walking to front porch, and cam activates (thus activating light)--what woudl happen when the motion woudl activate the light? If the light is on already due to camera motion rule, woudl the light then turn off? Is the concept with the lights just "on/off" so that if its on, and motion activates it, it woudl then switch off?
Appreciate some guidance.
thanks
steve_t
Master Master
I have mine set up so the camera triggers the light and also the light triggers the camera. Whichever device detects motion, there will be a recording (and a light if it's dark enough)
I think for your scenario, the light would stay on. The system knows when the light is on or off.
BUT... I'll have to test if that's still working when it's dark tonight because I've just noticed another cross triggering rule isn't working. I have a camera A motion triggers camera A and camera B to record. It's worked fine until today where camera B is no longer recording when camera A detects motion. The same might apply for the lights now
Nanookie
Thanks, Steve. The rules seemed to have worked, no conflicts.
  • 2 Replies
  • 4427 Views
  • 2 Likes
