Comparison of Arlo Pro vs Arlo Pro 2
What are the advantages of Arlo Pro 2 over Arlo Pro other than the higher resolution.? Is 24/7 recording available on either, with the addition of a back up drive or must you purchase a cloud plan for this feature.? All cameras will be plugged in. I am looking at 3 camera packages.. The Pro 2 adds a significant amount to the purchase price..
You can compare the devices here.
Arlo Products
The 24/7 is a service plan (CVR). you can review the plans here.
Service Plans
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
